Ir para o conteúdo principal
O SteelSeries Stratus Duo é um controle sem fio multiplataforma para jogos no Windows, Android, Oculus Go e Samsung Gear VR. Foi lançado em fevereiro de 2019.
Does this controller vibrate during game play?
Hi I bought a steel series stratus duo controller and realized the controller doesn't vibrate. Is mine a defect or is this not a feature on this particular controller?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
The SteelSeries Stratus Duo is designed to provide haptic feedback (vibration) during gameplay on compatible devices. If your controller isn't vibrating, it could be due to a hardware or software issue. Maybe try some of this
  1. Check the software: Make sure you have the latest firmware installed on your controller and that the device you're using it with is compatible.
  2. Check the settings: Check the settings on the device you're using the controller with to ensure that vibration is enabled.
  3. Try a different device: If the controller isn't vibrating on one device, try using it with another device to see if the issue is specific to that device.
Good Luck!
Esta resposta foi útil?
Pontuação 0
stratus duo has 0 vibration . ive taken this apart. there are 2 weights in the handles. no trigger motors.. and doesnt look like the pcb even has a place for vibration.
Pontuação 0
Adicionar a sua resposta
Christopher Hernandez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 1,065
