Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
612 Perguntas Visualizar todos
Screen wont turn on after replacement
I replaced my macbook air screen. Took off the back portion disconnected the fan and everything and then removed the screen as described in the ifixit guide. When I attached the new screen and put all the parts together, the screen wont work. I thought maybe it was defective and put the old screen back on but that one wont turn on either. The computer turns on because I hear the chime but nothing shows on the screen. What did I do wrong?I replaced my macbook air screen. Took off the back portion disconnected the fan and everything and then removed the screen as described in the ifixit guide. When I attached the new screen and put all the parts together, the screen wont work. I thought maybe it was defective and put the old screen back on but that one wont turn on either. The computer turns on because I hear the chime but nothing shows on the screen. What did I do wrong?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
First, Can you check if the video cable is fully inserted. Secondly, plug a monitor into the macbook and check if that gets video, if nothing happens then likely the logic board was damaged during the repair,
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thank you for your help ! I hooked my computer up to the HDMI and it works on that screen. So I think I received a defective replacement screen. I have ordered another replacement and will see if that works.
por
Awesome! glad i could help!
por
Adicionar a sua resposta
Shaneise será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 21
