Ir para o conteúdo principal
Um console de videogame para TV produzido pela Sony Computer Entertainment; o PlayStation 4 Slim (CUH-2000 Series) é o modelo sucessor do PS4 original. Data de anúncio: 7 de setembro de 2016.
569 Perguntas Visualizar todos
Why the IP Address cannot be obtained to my PlayStation 4 Slim?
How can I fix my PlayStation 4 Slim?
I cannot obtain the IP Address every time I try to connect to my PS4 Slim my WiFi still works. I can still use my PS4 Slim but I cannot use the online systems or updates. I would like to know what steps I need to take to fix my PS4 Slim and if there are any specific tools or parts I need to purchase.
Edit: I tried to reset the modum but it doesn't work and it's breaking/corrupting my little brother tv and HDMI something is very wrong with the ps4
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
This is likely going to have to do with your router, which is probably serving as the DHCP host on your home network. Try turning it off and on again.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I already tried that and the PS4 Slim still cannot to the Wi-Fi.
por
First, try resetting your modem and router to see if that helps. You can also reset your PS4's network settings and restart the console. If none of those steps work, you may need to dig a little deeper and check your router's settings to make sure your PS4 is allowed to connect.
If you still need help, contact IP checker API to get more details about your IP. I hope that helps. Good luck!
Pontuação 0
Adicionar a sua resposta
Andruw Holland será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 131
