Ir para o conteúdo principal
The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
Logic board compatibility between 11" and 13" models
I have a early 2015 MacBook Air 11" and want to upgrade from the 4GB board to an 8GB board. Is the board the same as the one in the 13" model?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sadly they are not, at least not in form factor. Even though many of the onboard components are the same, the layout is just different enough that I’m not convinced this would work without modification. For example the trackpad connects on opposite sides of the battery connector. Also the battery connectors are different.
I have never checked to see if a 13” board would mount in an 11”, but based on the locations of board mounting screws, I doubt it.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Just not possible!
por
Adicionar a sua resposta
todd S será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 144
