Ir para o conteúdo principal
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
423 Perguntas Visualizar todos
MacBook Air 2017 Shuts Down Randomly
Hey, my MacBook started acting strangely last month, it was shutting down randomly. I thought the problem may be about the battery so i replaced it, it worked amazingly for two days and now the same problem still continues. I tried powering it on with the battery disconnected, I cleaned the fan and the dust but still no luck. It boots then after 4 to 8 minutes it shuts down. I checked the shutdown messages and all i got is -128 error code. Booting from Safe Mode and Apple Diagnostics is no luck too, the same problem occurs. The only thing that works is macOS recovery. I would be super happy if you can help me.
OS: macOS Monterey
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
At this point you need to do a deep inspection of the logic board (both sides) to see if any components look damaged (burnt) as well as any corrosion.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Demir Demircioglu será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 93
