Ir para o conteúdo principal
2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
Installation of an Samsung SSD 870 Evo
Hi
I purchased a Samsung ssd 870 evo hard drive, and I am trying to install this. But the connection is not the same as the old hard drive. How can I get this installed? Is there a new cable that I can buy or some other trick?
Glad if you could help me
Eric
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Sadly, Eric Apple did their own thing with their blade SSD’s.
The Samsung 970 EVO SSD is a M.2 SSD and is not designed to work in your system without an adapter (if it supports PCIe/NVMe drives which this system doesn’t).
This MacBook Pro is an mSATA based system as you can see in this great guide The Ultimate Guide to Apple’s Proprietary SSDs so this SSD won’t work as it’s a PCIe/NVMe drive. You will need this SSD OWC Aura Pro 6G SSD and follow this guide MacBook Pro 13" Retina Display Late 2012 SSD Replacement
Imagem de Replace or upgrade the SSD in a 13" or 15" MacBook Pro with Retina Display from 2012 or Early 2013.
Produto
OWC Aura Pro 6G SSD
$49.99
Esta resposta foi útil?
Pontuação 0
2 comentários:
870 EVO is 2.5 inch boxy SATA SSD.
por
@tomchai - Yes, the 870 is a 2,5 SATA drive given the system chosen it wouldn’t physically fit and the clue of the connector being different tells us Eric got a 970 M.2 drive and had a slip of a digit here. While similar it still won’t work as it’s a PCIe/NVMe drive and this series only works with mSATA.
por
870 EVO is designed as an 2.5 inch spinning drive replacement SSD, the case physically will not fit in a Retina MacBook Pro.
Even if you take out the case and put in the naked board directly, getting an adapter will be extremely tricky. Most adapters are designed the other way around, converting Apple SATA SSD into generic SATA, opposite of what you want.
At this point it is easier to just buy a correct SSD.
Pontuação 0
Adicionar a sua resposta
eric lorentzon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 1,021
