Ir para o conteúdo principal
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Perguntas Visualizar todos
Camera not working (green light blinking)
My camera is not working, but the green light is blinking. When replacing the battery recently, I inadvertently pulled the wire out of the airport antenna cable connector. I think that may be causing the camera to not work. I've explored all the other possible solutions. Where can I get another connector? Or, is there a way to use the old connector?
MacBook Pro 15" retina late 2013
Thanks in advance, Tyler
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Did you pull the wires out of the cable end connector or did you pull the logic board connector off?
Update (01/16/2023)
Sadly, the cable end connector is a molded on connector so when you pulled the wires out you can’t reconnect them to the connector. The only thing you can do is replace the entire cable unit but I’ll warn you it’s not easy! As you first need to remove the display assembly following this guide MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement and then you need to carefully lift off the display panel out of the shell. We don’t have a guide to do that but here a peak on what it looks like MacBook Pro Retina Display Teardown jumping to Step 10 we can see the full cable unit which needs to be replaced, and lastly the part TheBookYard UK - Macbook Pro 15" Hinge - Right Antenna/iSight Cable (L13-15)
Imagem de MacBook Pro 15" Retina Display Mid 2012
Guia
Nível de dificuldade:
Moderada
Imagem de MacBook Pro 15" Retina Display Late 2013 Display Assembly
Guia
Moderada
1 - 2 hours
Esta resposta foi útil?
Pontuação 1
1 comentário:
The wire came out of the cable end connector (the same as in the photo). When replacing the battery, I tried to reconnect it, but now uncertain it is secure. I have not opened up to see if it's loose yet - just trying to find out if a new connector is available before I do.
por
Adicionar a sua resposta
Tyler Campbell será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 21
Duração total: 280
