Ir para o conteúdo principal
Released September 20, Apple's flagship 2019 smartphone features a 5.8" OLED display, a triple-lens rear camera, and greatly improved battery life. Successor to the iPhone XS.
132 Perguntas Visualizar todos
Physical Dual sim iPhone conversion from single sim and esim.
Can I change my iPhone 11 Pro SIM card reader from single sim & esim to physical dual sim by just changing the existing SIM card reader to a physical dual sim one.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Pergunta mais útil
It is possible. But the conversion is not as simple as just swapping the SIM reader out. It is soldered onto the board in this model and you would need to disable the eSIM so the phone will not utilize it.
This requires splitting the two layers of the logic board and removing some components in addition to swapping out the eSIM
Esta resposta foi útil?
Pontuação 2
Hi
I don’t think this is possible for 2 reasons
1)the sim card reader is soldered to the logicboard so if you would need good soldering experience to replace it
2)knowing apple they probably have this locked down as they have a quite the history of locking parts to the device to adding functionality is probably something that they are all over;-{
Hopefully this helps
Any questions please ask
Pontuação 1
1 comentário:
The sim reader is held in with screws and not soldered in. You can buy dual sim card readers online but it may not work. Take a look on YouTube. I'm sure there's a guy put a video on about it. Maybe Hugh Gefferies.
por
Check online
Pontuação 0
For 11 pro, this is an advanced level modification, soldering required to replace the SIM tray and modification of ID resistors.
If you need to ask at this point, you are not the right person to perform such modifications.
Pontuação 0
Adicionar a sua resposta
Sundeep S Bhosle será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 40
Duração total: 587
