Ir para o conteúdo principal
Repair guides and support for smartphones manufactured by Doogee.
Trying to get the screen out to replace charging port
My Doogee S59 Pro's charging port was broken by a cheap type C charger, and it has glue all around the screen, which I need to remove to access the Charging board. Does anyone know of something that will dissolve the glue?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Heat! Just apply heat (100C) around the screen for 8 to 10 minutes, then pry on it (gently). I've been trying to get it out for months then saw this video! https://youtu.be/LM5Qae_A5oU
Esta resposta foi útil?
Pontuação 1
1 comentário:
hi there, i have the same problem, did you finally replace the charging port ?
por
Adicionar a sua resposta
Anchevauls Walker será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 407
