Ir para o conteúdo principal
Lançados no final de 1993, o Macintosh Quadra 610 e o Macintosh Centris 610 são dois computadores pessoais intimamente relacionados que fazem parte das séries Quadra e Centris de computadores Macintosh da Apple Computer, respectivamente.
Why won't the computer start?
no image start up on monitor
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Any sounds? Does the motherboard runs? Do you hear power supply unit working?
There may be many reasons:
- power supply is dead (if nothing happens after power-on)
- battery is dead
- chipset is dead
- memory is dead
- tarnished contacts (power is not supplied to motherboard at all, or not enough power for components)
opix.pl
Esta resposta foi útil?
Pontuação 1
4 comentários:
replace battery, and it does not work--- hear not working tune;
hit option command R and P along with start button, and does not work--- hear not working tune,
por Compartilhar
also, green light comes on, but no screen picture, just the not working tune.
por Compartilhar
In addition, the computer worked the last time I used it 15 years ago, that's why I thought replacing dead lithium ion batter would revive it, but no, just the I'm not working tune plays. In additon, I can hear the hard drive, and fans working.
por Compartilhar
it is more possible that the video wire may be broken, or the VGA adapter is corrupted (try by AV cables if you connected it earlier via adapter). If not I would open the chassis and look for solder cracks. Ah sorry I didn't noticed you mentioned not working tune - focus on the hardware, skip video wires, I was wrong.
por Compartilhar
The first thing I would do is install an new 3.6 volt 1/2 aa Lithium PRAM battery.
You can get it here: https://www.amazon.com/Brand-LS14250-Lit...
Pontuação 0
1 comentário:
good choice for 1st step - usually computers do not die if not used, but internal batteries runs out :)
por Compartilhar
Adicionar a sua resposta
Denton Fender será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 33
Ao todo: 584
