Ir para o conteúdo principal
The Samsung Galaxy A10s is an Android smartphone developed by Samsung Electronics, and was released in March of 2019.
Why is my wifi and bluetooth not working
Why is my wifi and bluetooth not working Why is my wifi and bluetooth not working
Esta é uma boa pergunta?
Pontuação 101
29 comentários
Has the phone been dropped or damaged at all?
por
I did factory reset but still not working
por
I went in my hardware but my wifi and bluetooth are not listed in and its says unavoidable
What must I do
por
I'm having the same issue on my Samsung Galaxy Note 20 Ultra. After the new update, they both stopped working.
por
Check (verify) the time zone on your phone. I had this problem On the last update and resetting the TIMEZONE corrected the problem.
por
Exibir mais 24 comentários
Adicionar um comentário
29 respostas
Pergunta mais útil
There could be several reasons why your WiFi and Bluetooth are not working on your Samsung Galaxy A10s. Here are a few things you can try to troubleshoot the issue:
  1. Restart your phone: Sometimes, a simple restart can fix minor software issues.
  2. Check if the WiFi and Bluetooth toggle switches are on: Go to Settings > Connections and make sure that the toggle switches for WiFi and Bluetooth are turned on.
  3. Check if the WiFi and Bluetooth chips are enabled: Go to Settings > About phone > Hardware information and make sure that the WiFi and Bluetooth chips are listed as enabled.
  4. Check if there are any software updates available: Go to Settings > Software update and install any available updates.
  5. Check if there are any issues with the router: If you're trying to connect to WiFi and it's not working, try connecting to a different WiFi network to see if the issue is with the router.
  6. Reset the network settings: Go to Settings > General management > Reset > Reset network settings. This will reset all the WiFi and Bluetooth connections on your phone.
  7. Factory reset your phone: If none of the above solutions work, you may have to perform a factory reset of your phone. Keep in mind that this will erase all the data on your phone, so be sure to back up your important files before doing this. To factory reset your phone, go to Settings > General management > Reset > Factory data reset.
Esta resposta foi útil?
Pontuação 28
37 comentários:
I did factory reset but it still doesnt wrk
por
Hi I did all but didn't work
por
After the last Samsung update my wifi and Bluetooth isn't working as well
por
Same for me, bluetooth and wifi can't be on. when I tried to open it it'll become off again.
por
Same here to me
por
Exibir mais 32 comentários
الخلل في ايسي بلوتوث والحل استبدال الايسي او تسخينه راح يرجع الجهاز طبيعي
Google translate:
The fault is in the bluetooth eSee, and the solution is to replace the eSee or heat it up, and the device will return to normal
Pontuação 10
10 comentários:
how to replace the esee or heat it up?
por
Oh my gosh I did everything but still won't connect I'll just chill here and wait for the answer
por
I am facing the same problem. My Wifi and Bluetooth is no longer working. Is there any Samsung Technician ca help me fix this problem? Thankyou.
por
I am also facing this issues wifi and Bluetooth devices is not working plz tell me solve the solution plz
por
Even if I refractory doesn't work
por
Exibir mais 5 comentários
If your WiFi and bluetooth not working it is because of Ic problem you have to change it
Pontuação 7
2 comentários:
I did perform factory reset but still the same. Help me out pls
por
How can we replace Or heat it where it is inside the phone?
por
If you have WhatsApp installed. Try cleaning WhatsApp data or uninstall WhatsApp. It works fine for me. A10S
Pontuação 4
4 comentários:
It's a hardware issue. The phone's IC has a problem that's why the Bluetooth n WiFi don't work. The technician will demand approximately R250 to R350 to fix it.
por
No hardware issue this is new update issue.
por
Not an update issue. My phone has not received an update in years because it an old phone (Galaxy J5 prime). So it is a hardware issue-
por
My Samsung a10s have the same problem
por
turn on bluetooth to connect to nearby devices
Pontuação 4
1 comentário:
Still my phone doesn't want to open
por
Reset your Wi-Fi router. The location of the reset button depends on what Wi-Fi router you are using but every Wi-Fi router has one.
Pontuação 3
1 comentário:
Thank you, Anthony, but this is not a solution to problem.
por
Why is my wife and Bluetooth working
Pontuação 3
Try to format your phone
Pontuação 3
Heat ic 300 ⁰c but how can i show the ic
Pontuação 2
Well I will suggest to do the software update or system updated of your phone. Sometime outdated software version can also cause these kind of issue as well.
Pontuação 2
3 comentários:
You can't update phone without WiFi
por
Even if I restart don't enable and not op6
por
I did restart but still is not working
por
Its hardware issue my 2 devices one got resolved heating ic and second one had replaced ic MT6631N
Pontuação 2
Wifi end blootot hospot
Pontuação 2
WiFi not opening
Pontuação 2
1 comentário:
Since the problem occurred with all users of this version of Samsung, this means that its function was stopped in the latest Samsung update.
por
My wife and bluetooth are not working on my phone my phone is Samsung A10s
Pontuação 1
Pontuação 1
Bluetooth 11
Pontuação 1
1 comentário:
WiFi and Bluetooth connection is not working
por
I have an S20+ and a WiFi 6 home network. I'm running the May 2023 update to OneUI 5.1.
Suddenly last night I was unable to connect to my home WiFi network. WiFi worked fine for all my other devices. I did lots of Google searches.... After trying all the obvious simple things (toggling Airplane Mode, Rebooting the phone, etc.), I looked in the S20+ Settings / Developer Options this morning and found "WiFi non-persistent MAC randomization" and turned it ON. WiFi almost instantly started working again on the phone.
I hope this helps others.
Cheers,
Scott.
Pontuação 0
My wifi and bloototh not working
Pontuação 0
My wifi and Bluetooth malfunctioning since last 2 months
Pontuação 0
Why my wife and bluetooth not working on network
Pontuação 0
5 comentários:
por
My bluetooth and wife are not working my phone is Samsung A10s
por
Me 2 my Samsung A10s is not working
Bluetooth, WiFi and hotshot won't connect
por
My wifi and bluetooth not working
por
My Wifi and Bluetooth is not working in Samsung s20+ and developer option is also turned off
por
Pontuação 0
My wifi & bluetooth not working, I have samsung Fold 3… .I got sick of samsung, Im going to buy Honor magic v3
Pontuação 0
Wifi Bluetooth not working why problem factory already but not solve
Pontuação 0
Why Bluetooth say disconnected
Pontuação 0
1 comentário:
Answer me plz
por
I do no but it's is in software complaint
Pontuação 0
How i can fixit
Pontuação 0
Pontuação 0
I don't no but I want to learn
Pontuação 0
f your Wi-Fi and Bluetooth aren't working, start by restarting your device and router, and check for simple issues like interference or drivers being outdated. If those don't work, try resetting your network settings, which will erase saved Wi-Fi passwords and Bluetooth pairings but can resolve connection problems. For persistent issues, consider updating your system or, as a last resort, performing a factory reset.
Pontuação 0
Adicionar a sua resposta
Yidnekachew será eternamente grato(a).
Visualizações:
Últimas 24 horas: 22
Últimos 7 dias: 118
Últimos 30 dias: 655
Ao todo: 77,416
