Xbox want turn on and took it apart and cleaned it and didn't see any
Xbox one s all digital want come on or anything
Esta é uma boa pergunta?
Does it come on into safe mode? Hold the sync button and press (and release) the power button.
If not, have you tried replacing the power lead? I’ve seen a few faulty ones. Ask a friend if you could borrow theirs to test
Esta resposta foi útil?
Double check all of your connections to make sure you don't end up doing unnecessary repairs. It's easy to not plug something in right. It's not likely, but there is also a chance you could have knocked the power button off the IR blaster daughterboard. I did this during a repair, and I came to realize how easy it was to knock of the tiny little buttons. A way to test this is to listen or feel for a click when you press the power button. If it is broken, here is the part you will need to fix it: Xbox One S RF Board and IR Blaster
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 32
