Correlation between battery service and usb c not working fine
Hi. I’m going to buy a used MacBook Pro 13” 2017. The guy says that the battery needs to be replaced and that (he thinks) can be a correlation between the battery problem and the usb c not working fine.
This is going to be my first Mac, I always had Windows and even at work I deal with that as a technician so I’m not into Mac so much for being sure is the battery that causes that problem or if is something else.
Someone with experience can help me? As I mentioned, I’m a technician so change battery or do something else is not a problem. I’m trying to understand if the port are dead or if needs just a battery replace. Thank you so much!
Esta é uma boa pergunta?
