Ir para o conteúdo principal
Guias de reparo, desmontagem e informações sobre a resolução de problemas para o Apple iPad de 8ª geração com Wi-Fi, disponível com 32 ou 128 GB de armazenamento. Lançado em setembro de 2020. Identificado pelo número de modelo A2270.
Replacement screen is a bit blurry
I replaced the screen on my iPad and the screen dose not look even close to as good to the oem one in the pic it is hard to tell but the white one with a replacement screen is worse.it is almost like there is another layer of protective plastic that needs to be removed even know I took off all the plastic that had tabs of was obvious, even after taking all the plastic off it has manny scratches. I’m looking to know if there is another layer of plastic or any good brands to get another screen from.here’s the link to the screen that I got MMOBIEL Digitizer Front Glass... https://www.amazon.ca/dp/B08H8PQX6B?ref=...
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
hello Josh,
unfortunately, I have bad news for you. The digitizer is of low quality and astronomically expensive. I even think you overpaid at least 2x. The nice curve of the digitizer tape defends itself (glueing), sloppy tapes usually rise and cause the surface of the screen to rise. However, I expect poor quality glue on the edges, and the scratches are terrible. Worldwide, this digitizer costs about $12 and in the version without glue, folded tapes and front camera bracket even $8
such a digitizer like this one should have two pieces of protective plastic: one on the outside and one on the inside. The inner one acts as an antistatic dust barrier, the upper one should protect the antiphobic coating, which is probably not here, but that's another thing.
Are you sure you removed both layers of plastic? If you also replaced the matrix, there will also be a protective plastic on this one. More details can be found here - step 20-21
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Josh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 487
