Ir para o conteúdo principal
No pod required, single serve coffee brewing system with built in frother. Coffee drinks that can be made hot, iced, or other specialties and from a one cup serve to multi-serve. This device can be identified by its model number CF111 30.
Why does my Ninja brew less water than specified?
No matter what setting I choose, my Ninja brews less than 4 oz. It also leaks but I wouldn't think the small leakage amount would cause it to not brew 8 oz when selected. What could be the problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Jeff Vince asked a similar question 6 years ago.
Why does my Ninja brew more water than specified?
It seems to be the opposite of his answer. You under-filled the reservoir.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Robert Roy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 183
