Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone 11. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 11.
Recovery query on iPhone 11
Hi all,
Is there any way to check if someone has done or attempted to do an iPhone messaging recovery on my iPhone 11 using one of those free apps. I think someone has done it without my permission.
Thank you
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@dean8015, As far as I know, no such apps / applications talk back to the iPhone and “leaves” a trace about being used.
Same way when I recover (or try to recover) data from a disk / SSD, when I run my apps, it only goes sector by sector seeing what’s there. If data were written to a sector, and not overwritten it can bring it back.
There are only two ways of truly deleting data:
  1. Overwrite every single sector with new data, to completely wipe what was there (back when I took my certification, DoD standards required the sectors to be overwritten 7 times in order to be deemed deleted.)
  2. Expose the disk to high intensity magnetic fields (degaussing). That will destroy the data if powerful enough
None of these will leave a trace on the disk (other than the fact that the data has been deleted). Disk(s) show zero information about having been attempted recovered.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Dean será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 87
