Ir para o conteúdo principal
Repair and service information related to the ResMed AirSense 10 CPAP machine. Also known as the ResMed Air10.
Why is it making a high pitched whistling sound?
It is 2 years old and suddenly one night when it turned on, it had a high pitched whistle sound and the pitch changed with each breath I took. It was continuous and I could not sleep a wink with it on.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I also experienced this. A sound from within the machine, a sort of wheezing sound that was apparent as I breathed in and out. It was a disturbing sound not having to do with an air leak from the hose, mask, or water tank, as I checked these possibilities first. I discovered the sound was coming from the motor itself. In my case, the motor in my machine was just five years old. I was able to replace the motor quite easily with the aid of a couple of YouTube instructional videos which were easy to find. I was able to purchase a replacement motor which I found on that large online shopping site. I believe it cost $129.00, and it arrived the very next day after I ordered it. I believe that just about anyone can replace their motor with the aid of an instructional video for which there are several on YouTube.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sheila Lusk será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 386
