Ir para o conteúdo principal
Monitor IPS LG UltraFine 5K de 27 polegadas com compatibilidade com o macOS
I can't open monitor back cover
Could you help with instruction how to open monitor back cover - I can't understand how to do it? I already have been removed 4 screws, but how to find clips and what to do next I can't understand.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
the back usually doesn't come off on monitors.
the typical teardown is done by removing the screws (which you've done) and then carefully prying the bezel cover away from the display from the front of the monitor.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I have a feeling that I need to do something with clips, etc. Because I can't remove easily cover :(
por
hm. when I took my monitor apart I had to use some force to get the clips off because they are held on fairly tight
por
Adicionar a sua resposta
Ihor Syrota será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 27
Ao todo: 1,287
