Ir para o conteúdo principal
Apple's fifth-generation smartwatch, with optional cellular connectivity, released September 20, 2019.
Apple Watch display lcd
I try to repair an Apple Watch serie 5 , but some but something go wrong when I try to attach the lcd display to connector , there is a solution for know if is the lcd screen broken or the connector ?
https://drive.google.com/file/d/1Y-9mF3X...
https://drive.google.com/file/d/1eZnVucF...
https://drive.google.com/file/d/1eawCLGr...
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Adding pictures of the back of the screen ribbons and the connectors on the board would help.
por
Thanks Nigel, i have added the photo
por
Adicionar um comentário
1 resposta
Sadly your OLED display is damaged! It looks like you had a hard time getting it off as the displays edge looks damaged, but the worse is the damaged connector on the backside. It also looks like the ribbon cables are a bit tattered as well.
In any case you need a new display.
Esta resposta foi útil?
Pontuação 0
3 comentários:
Can you recommend a site where to take the display with advantageous prices?
por
I had tried to separate the touch display from the lcd display…
But if you tell me this, I order new display.
por
@Leonardo Barbieri - You’ll need the full display assembly which includes the crystal, touch & OLED display. These can’t be gotten separately.
Sorry I don’t have any parts source anymore to recommend.
por
Adicionar a sua resposta
Leonardo Barbieri será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 181
