2010 MacBook Pro does not chime and has no display on startup.
I was using my laptop as normally a few days ago. I had the display at low brightness and the volume turned off (not sure if this has something to do with it).
I let the computer run out of battery. When I charged it overnight, the indicator on the side said it was full but when I went to power it on, nothing showed on the display and I could not hear a chime. I did hear the fans spin and the disk drive made a noise but that was it.
I also have the disk partitioned so sometimes when it restarts it boots into a blank screen that says something like "no bootable drive found" but normally I can avoid that by pressing option and selecting my drive. Is there a common fix for this?
I have tried plugging it into an external display but there was no output. I have also let it run out completely from the fans spinning and charged it again, but it still has not made a difference.
I did change the battery, but that was in September and it has been working fine since then.
Fix: I left my computer alone for a week or so and I tried resetting the pram. I pressed the power button while hold command option p and r and I heard the chimes. After the display booted back on, I realized it was booting into my second partition of windows, which is extremely glitchy. Once I tried to boot it into mac, it worked fine.
Esta é uma boa pergunta?
