Ir para o conteúdo principal
My controller suddenly stopped turning on
My Xbox just stopped working, it wont turn on, i even put new batteries, but same result, the past day, it was working perfect but suddenlumy it just stopped, help?
Esta pergunta é pertinente?
Pontuação 1
3 comentários:
mk, just confused about one thing;
is the xbox not turning on, or the controller?
did you get it wet or do anything that could damage it?
if the controller is not turning on, try connecting it to a computer wirelessly and by plugging it into the computer, and tell us what happens.
por
The controller is not turning on, it didnt happen anything so that could damage it, I cant connect it wirelessly into the computer because it wont turn on, and by plugging it, it doesnt turn on either
por
i think its a bad battery contact or a logic board issue.
is there corrosion on the battery contacts that you can see?
i think it might be time to open it up and take some photos/look for anything broken or weird looking
Adicionar imagens a uma pergunta já existente
this can help you take it apart
https://www.youtube.com/watch?v=LpbxRYof...
por
Adicionar um comentário
1 Resposta
Hi, you should check the battery.
Esta resposta foi útil?
Pontuação -1
Adicionar a sua resposta
Lucas Lustosa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 29
