Ir para o conteúdo principal
Opções de armazenamento externo da Seagate, geralmente conectadas via USB, disponíveis em muitos tamanhos de armazenamento e formatos.
Seagate Business NAS acting abnormally
I have just acquired a Seagate Business NAS 2 bay. It didn't have the original power supply, so I bought one from Amazon. It seems to work normally, but I'm unable to turn the unit off via regular methods. I connected it to my network and downloaded the requisite software. The software found it, and I can access the maintenance page via IP address in my browser. It even found the hard drives I put in there.
The problem is I'm unable to factory reset it so I can make use of all functionality. I followed the instructions in the manual and it refuses to reset. Is there anything else I can do to make this work?
Esta é uma boa pergunta?
Pontuação 1
9 comentários:
@enron_hubbard how did you try to reset this? Which one of these steps does not work for your device https://www.seagate.com/manuals/network-...
Flashkey? Interesting. Probably has the NAS-OS on it to reboot and reset. https://www.seagate.com/support/kb/busin...
See what you can get from here https://www.seagate.com/support/external...
por
When it was on, I held down the reset button in back. First for 5 seconds, then 10,then 15. The manual stated the light would flash, but none of that happened.
por
@enron_hubbard Used the paper clip yet :-) ?
por
@oldturkey03 Is there another reset hole that only a paper clip can fit in? I was able to poke the button with a pen.
por
@oldturkey03 This thing refuses to turn off or reboot. Short press, long press, this thing just stays on. Is there a USB key I can make to automatically load NAS OS?
por
Exibir mais 4 comentários
Adicionar um comentário
1 resposta
Have you tried contacting Seagate support? I would do that.
Esta resposta foi útil?
Pontuação 0
2 comentários:
The unit has been out of warranty for years, typically companies just direct you toward buying a new unit.
I searched for forums but apparently Seagate has shut theirs down.
por
@enron_hubbard - That maybe true, but if you don’t ask there’s little we can help here.
por
Adicionar a sua resposta
Jay Davidovich será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 21
Ao todo: 596
