Ir para o conteúdo principal
Model numbers JSN-L21 and JSN-L42.
25 Perguntas Visualizar todos
Why is my screen have light borders on it that I cannot removed?
not too much dark i cc still see the figures down on it its like a shadow border
Esta pergunta é pertinente?
Pontuação 0
4 comentários
rodolfo, can you take a picture of what you're seeing and add it to your post? I'm having a hard time figuring out what the problem is just from your description. Does the same problem show up when you take a screenshot?
por
Here's how to edit your list too add a picture: Adicionar imagens a uma pergunta já existente
por
elaborate and send pics
por
@dadibrokeit yes sir same not coming out even on screen shot
por
Adicionar um comentário
1 Resposta
Solução escolhida
@asiongbautista Anything physically wrong with the screen won't show up on a screenshot, since it's saving the digital image that's going to the screen rather than what you actually see on the display.
Do you have a screen protector on it? What I see in that picture looks like the the outside edges of a screen protector that isn't adhering to the screen any longer. I suspect if you simply remove and/or replace the screen protector you will probably fix your problem.
Esta resposta foi útil?
Pontuação 0
2 comentários:
sir if screenshot still same the border still there its not removed i said i tried to erase all same nothing happens
por
i removed my screen protector but still the same sir not yet fix
por
Adicionar a sua resposta
rodolfo bautista será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 49
