Ir para o conteúdo principal
O Sega Genesis (também conhecido como Mega Drive) é o console de jogo mais bem-sucedido da Sega até hoje.
Power switch replacement, is it easy?
so i have two Genesis model 1 consoles and one has a very stiff power switch and the other console doesn’t work but the power switch is very easy to slide. So I want to swap the power slide switch but I can’t find any videos about this. However, I’ve seen a photo of one that was removed but the guy that took it off said he broke it and in the photo there was a spring beside the switch. I guess I just want to know if I desolder the switch, is it going to just fall apart on me?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
So I no longer need to worry about swapping the power slider switches, I bought some lithium grease and worked it into the slider switch and now it slides like butter.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
It could be a build up of dirt causing it to be stiff. I’d try cleaning it first. Very old machine so greasy fingers over time could of clogged it up.
Pontuação 2
1 comentário:
Yeah I used some contact cleaner and it helped a bit but still too stiff when the case is put together. I’m going to try some lithium grease first (being delivered today) and see if that helps. But if not, I wanna try and swap them.
por
Adicionar a sua resposta
Kevin F será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 32
Ao todo: 1,214
