Waring: Card door opened.
when I start my Kodak DX3215, I get an error: Waring: card door opened. But it’s locked. Help!
Esta é uma boa pergunta?
@nivito1 It sounds like you Esther have a faulty micro switch or sensor, that detects whether the card door is open or not.
If you are fairly comfortable with DIY and have and can use a DMM (digital multimeter), you could try taking the camera apart enough to get access to that switch / sensor, then test it using the continuity mode on the DMM.
Take some good quality and up close pictures, then update your question. Adding images to existing questions. Maybe we can see something suspicious.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 91
