Ir para o conteúdo principal
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
267 Perguntas Visualizar todos
PS Button and parts of the D-Pad not working
Hi! So, I recently wanted to boot up my PS4 again and play some games with a friend... but then the controllers wouldn't turn on. I tried connecting them to my PC - they worked but when I connected them to the PS4 they refused to work with it.
I thought it's battery issues so I left them to charge and afterwards they wouldn't work yet again. I opened them and saw nothing wrong... and then it hit me. The issue is the PS / Power button.
I connected the controllers back to my PC, installed DS4Windows, mapped all buttons to keyboard keys and opened a key logger. Everything except some of the D-Pad buttons and the power buttons worked.
Now, the buttons themselves seem completely fine. There's no visible issues. Can it be the little transparent / green plastic thing that stays under the buttons? If it is, can I replace it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Whoa, this was back in December?
Anyways, I ordered two replacement membranes and swapped them. This fixed one of the controllers, however I &&^&@@ up the ribbon cable for the USB of the other one so I can't really confirm if it fixed it.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Check the black parts on the clear rubber for the buttons are clean. Also clean the contacts on the board with an eraser then try it.
Pontuação 1
5 comentários:
Hey, sorry for the late reply.
Can you be more clear about what you mean by "clean the contacts on the board"?
por
@uskizzik on the flex where the buttons are. There are some contacts where the buttons sit above.
por
So the black parts right below the buttons? Clean them with an eraser? Like... a pencil eraser?
por
@uskizzik yes but gently. You’ll see the film with the contacts I’m talking about in step 7 on this.
How to Fix PS4 Controller Analog Drift (R3 or L3 not working)
por
@strongbow Didn't seem to improve at all...
por
unfortunately this is an indication that the Flex Ribbon Connector is starting to wear, this is either a simple fix with some 99% ISO Alcohol and a cotton tip to clean where the Circuit board meets the Ribbon or a replacement ribbon entirly
Pontuação 0
Adicionar a sua resposta
uSkizzik será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 25
Duração total: 398
