Washer can't go into rinse and spin
Washer can't go into rinse and spin, it tries but can't ingage
Esta é uma boa pergunta?
Hi @fishlake
I assuming that you mean that the wash tub tries to spin but can't and not that the washer's cycle timer can't step on to the rinse cycle from the wash cycle, as your question is a little ambiguous, is this correct?
If the cycle timer does step through the cycles OK but the machine can't spin during the rinse or spin cycle it may be a problem with the drive coupling
The supplier link above are only to show the part, they also have a video that shows how to replace the part and they have the manufacturer's part number listed as well.
If this is the problem, search online using the manufacturer's part number only to find suppliers that suit you best.
Esta resposta foi útil?
Coupler was replaced with transmission. .
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 79
5 comentários
Hi @fishlake,
What is the model number of the washer?
por jayeff
20882990 is the model
por Marvin
We've replaced the motor, clutch, transmission, and pump. It isn't the safety switch.
por Marvin
Also replaced timer the old and new still cause the same issue.
por Marvin
It's a Kenmore
por Marvin
