Ir para o conteúdo principal
The Xiaomi Redmi 9A is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a 5000 mAh battery, and runs on a Helio G25.
I cannot hear someone during a call
WHy can't I hear someone during a call
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
The weakness of the network in phones is the most common reason for the problem of not hearing the voice of the caller. If the network is weak at the other end, ask him to change his location. If your network is weak, choose a better place where the signal strength is higher
Sometimes the problem of not hearing the caller's voice occurs, because your call volume is low, and one of the sound control settings on your phone is the call volume settings, which you can access through the control buttons
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
luyandayando51 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 296
