Ir para o conteúdo principal
An update to HTC's original Vive, now with improved displays, sensors, and ergonomics. Released April 5, 2018.
Will your Vive Pro Headphone replacement part fit the Vive Pro2?
Hi, I have a Vive Pro 2 Headset and the left earphone is failing [sound stops playing on the left side]. Will your replacement part [Item # IF453-028-1 HTC Vive Pro Headphones] fit the Vive Pro 2 headset?
I have already removed the left earphone and verified that the contacts are clean. The sound is intermittent. I need a replacement part for the left earphone that has the volume control button.
Has anyone successfully used these replacement headphones on a Vive Pro 2 Headset?
Thank you,
Edward
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hey, Edward.
As long as you're capable of doing it yourself, I'd say it's fine to use a Vive Pro Headphone replacement on the Vive Pro-2. There is not too much differentiation between the two headphone parts, and certainly not enough difference to cause an issue. I hope you find this helpful.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Edward Leslie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 177
