Ir para o conteúdo principal
The Dell Latitude 3340 13.3" Laptop features an Intel Core I5-4200U processor and 8GB of memory. Store photos, music, movies, and more on the 256GB SSD Hard Drive.
6 Perguntas Visualizar todos
No audio from speaker nor the handsfree
How to fix my laptop its speaker is not working (no audio) there's no audio even with the handsfree. How can I fix this issue?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
you can first start y going into settings to check the audio settings because for some reason the audio can say disabled which makes it not play. you can also connect a bluetooth speaker ot the laptop if you have one to temporarily fix the problem.
if it is a software problem follow this guide (Microsoft Audio Guide for windows 10/11)
if it is not a software error you may need to replace the speaker.
Hope this helped.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Thank You I solved the problem, it was related to audio drivers.
por
glad i was able to help
por
@gabesech I appreciate your time thank you
por
Adicionar a sua resposta
zain será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 107
