Ir para o conteúdo principal
There are various different renditions of Saeco Minute coffee machines, also under the brand name Philips. All types start their Type Number with HD8xxx. Here you see a Philips HD8834.
3 Perguntas Visualizar todos
Where does the two pipes go from the water pump.
My coffee machine is tripping the earth all the time when making coffee and when I opened it, I saw two water pipes leaving the pump, one of them (clear one) is not connected to anywhere and tip is lying loose in the machine. Is this normal ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
See Saeco Minuto Pumpe tauschen, step 16. The pump ist connected top two pipes, one in (the clear one) and one out.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thank you. I meant the two pipes exiting the pump. One of them seems to be not connected to anywhere. I wonder if it is a pressure valve and the distal end is juts free/loose into the tray.
por
@Alp Numanoglu : can you take a photo? Adicionar imagens a uma pergunta já existente
por
Adicionar a sua resposta
Alp Numanoglu será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 101
