Ir para o conteúdo principal
Apple's smallest iPhone 14 was released on September 9th and comes with a 6.1" OLED display, an advanced dual 12 MP camera system, and a front camera with autofocus. Successor to the iPhone 13.
20 Perguntas Visualizar todos
Why does my iPhone 14 has a smudge on the display?
My Iphone has a smudge which can be visible mostly on grey screens and also can be seen on screenshots. This is weird, since i can see it in a screenshot i think it has some thing to do with software but I'm not sure.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
iOS 16.1.1 just released. Maybe you can try updating?
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Hi
It looks like it could be some form of
discolouration between the layers or the display
If it’s still in warranty it might be worth a shot taking it to apple to get it fixed under warranty however if it isn’t available you could replace the display to fix the issue
Here’s the guide for that
iPhone 14 Screen Replacement
However if it appears in a screenshot it is a software issue and could be fixed by restoring the phone or waiting for a software update that fixes it
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 2
3 comentários:
If it appears in a screenshot than it is probably not a issue for the screen.
por
@thequacker
I mentioned that in a edit :-)
I only realised it was a screen shot after I looked at it several times XD
por
Let's retrace:
  • If the issue is on your phone display but doesn't appear on a screenshot it is caused by a stain on the display, such as sauce.
  • If the issue appears on the phone display and screenshot it's a common problem caused by LCD damage or discoloration.
If it's the first issue grab paper towels and thoroughly clean off the display. If it's the second issue you have to replace the display screen either at home or at a repair shop. Just make sure your device still has warranty for qualified repair.
Pontuação 1
In my own experience, this could be a software bug. Please check on different software to see if the error appears on all applications, if it is always fixed at one point, then this is definitely a hardware error, now you need to bring the phone. this phone to an Apple service center for processing. In case of software failure, you can manually reinstall the new software.
Pontuação 1
Adicionar a sua resposta
Alon Karaev será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,232
