Ir para o conteúdo principal
Repair guides and support for the 24" iMac with M1 chip, introduced in April 2021. Identified by model A2438.
How to fix my slightly cracked screen?
My iMac fell on the floor and is still operating expeditiously but there is a crack that is somewhat visible but not massively visible. It extends from the top left hand corner of my iMac to the center of the computer screen and back down to the right hand bottom corner. Even though the crack covers a large area, the crack did not penetrate the computer and looks like maybe a cat scratched it or a slight laceration to someone's arm.
It is not essential to get this fixed but I would like to if possible. I have tried the eraser method, the Vaseline method, and hand sanitizer. Any ideas?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi
Unfortunately you will need to replace the display assembly as it’s the easiest option and for most people the only option unless you have the equipment to separate the glass and display
Here’s the guide to replace the display
iMac M1 24" Display Austausch
This guide isn’t fully finished but it should get you though the majority of it
If you could find a screen protector or privacy screen for your iMacs display it could help make the crack less noticeable
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 4
2 comentários:
Thank you so much for all your help. Do you know where the best option where be to buy a new display assembly?
por
@Elliot Swincher
Unfortunately because this model is soo new these parts are hard to come by so the only ones I could find are in other currencies
https://www.ebay.co.uk/itm/175443093964?...
This one comes from France but I would ask apple to see how much it is for them to do it for you as it could work out cheeper:-)
por
Adicionar a sua resposta
Elliot Swincher será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 59
Ao todo: 5,659
