MacBook does not turn on when battery board is connected
I have a MacBook 13" Touch Bar (2017) which after a minor liquid spill (coffee) which does not turn on when the battery board is connected. This startet about 2 days after the liquid spill.
When I disconnect the battery board, wait about 10 minutes and plug in a charger, the MacBook starts itself and everything words. Apple Diagnostics report no problems (except the missing battery) and everything is working fine (I let it run for over 24h without any problems). Sleep, restart, shutdown etc. all works as long as the charger is connected. When I disconnect the charger, I have to wait about 10 minutes before connecting the charger again, else the MacBook won't turn on. This is all while the battery board is still not connected.
If I reconnect the battery board cable while the MacBook is running in this state, the battery charges and everything works until I disconnect the charger (while the charger is connected, every works normal, Apple Diagnostics report no problems). The MacBook then keeps running on battery when the charger is disconnected, but as soon as is switched it off totally (not sleep) it does not switch on again. I then have to disconnect the battery board and wait 10 minutes, then it will automatically start again when connecting the charger.
I checked the board for liquid damage. There were some very little areas which were a bit dirty, which I cleaned and then let dry.
I'm looking for advice what to try next.
Is it normal that one has to wait 10 minutes after disconnecting the charger before reconnecting to start the MacBook or does that point to some error on the logic board?
Does it sound like the battery/board is damaged? The Battery is quite old (488 charges, service warning). Should I try to buy a new battery, or does everything I write sound like a faulty logic board? Since the device is a bit older, I do not want to spend that much money on it.
Thanks for any advice :)
Update:
Pictures (the dark oval was the area of the spilling, but there is no corrosion)
if i pull this cable and wait for about 10 minutes, then plug in a charger, the macbook boots and everything is working fine (as long as is stay on the charger, as soon as i disconnect the charger and then switch the macbook off, it does not turn on again)
Esta é uma boa pergunta?
2 comentários
@myel - I would look deeper into the SMC logic area reference the schematics and board-view drawings as you have a deeper issue within it. Do you have the skills to debug the logic? If not it’s time to find someone withe the skills.
Even GP Doctors know when there skills are not up to the task and get the patient to the brain surgeon!
por Dan
Thanks! Nope, probably can't debug the logic (while i can check some voltages and resistors, i do not even know where to start 😉).
I'll take a look at the SMC area again to see if there is still some dirt/coffee there (i doubt it).
If I can't find anything, I'll probably just leave it as it is. It works as long as I don't switch if off without being connected to a charger and even when that happens I just have to disconnect the battery board for 10 minutes and everything is ok again... 🤷♂️
por Myel
