Does MacBook Pro 16" 2019 still has screen flex/t-con problems or any
Hello,
I would like to ask if the MacBook pro 16" 2019 (latest model with intel) still has problems with the display connection. On my previous MacBook Pro 15" 2016 my t-con board stopped working out of the blue (display image went off and never came back on, had to replace the display) and I was told it was a manufacturing defect and could happen again. Has this problem already been solved or could something happen to my new MacBook Pro 16"? I was also advised when troubleshooting the display that there are also wear and tear issues on the flex cable between the display and the bottom if I open/close the display frequently. Does this also apply to the 16" macbook pro? On the older model, I also had a problem with the anti-reflective layer coming off on the places where it touched the keyboard. Can this be prevented somehow? I read that using the original "paper" that was placed between the display and the keyboard will prevent this. Is it true? I've also read that this problem can be exacerbated by carrying it in a bag where something puts pressure on the display lid. Is there a case that would prevent this? Alternatively, do you have any experience with protective glasses / foils? Someone claimed that the foil helped him, while others claimed that it damaged the display because it creates pressure on the display from the inside. I'm also wondering if you have any tips, tricks, things to watch out for when using this mac so that it lasts as long as possible in perfect condition.
Thanks for the answers
Esta é uma boa pergunta?
You have a lot of junk logic & science mixed into your question.
The only issue any display faces is being sat on causing excessive pressure cracking the metal oxide traces on the glass LCD which moves the signals from the driver logic to create the image. Placing anything between the display and the keyboard is more likely to enhance the possibility of damage as you are now taking up the space for the display to flex into before hitting the keys.
There is nothing you can do to enhance the protection or prevent damage. I do recommend getting a good case and mind where you put the accessories! I always use a different bag as even a charger brick pressed into the lid when something heavy is placed on top or wedged besides it will crack your display. A second issue is forgetting to take even a paper clip or staple sitting on the top case so when the lid is closed it presses on it damaging the chin plate or display.
por Dan
OK, thank you, but how can I prevent staingate then? I have it on my MacBook Pro 15" 2014 - keyboard and trackpad are printed to the display, because they removed antireflective coating in some places. I would like not to see something like this in a few years on my 16" 2019 model.
por Andrej Pracovný účet
That’s a very different question! StainGate is a failure with the anti-reflective coatings. You can’t fix it most people just remove it and live with the glare. Can’t alter the risk as Apple doesn’t offer a mat screen.
I had someone who does glass etching mat finish my 2015 15” MacBook screens. It took us I think four attempts to get it just right. I had three screens done. I also use a larger 27” and 34” displays when home (I’m. Photographer at heart)
por Dan
Yes but the questions isn't how to solve existing staingate issues, but how to prevent it from happening on new model.
You really can’t prevent it, once the coatings are damaged that’s it.
The coatings now used are better than what they had back in 2015 and the bigger mess was the top coat failed, but over time can be rubbed off.
por Dan
Exibir mais 1 comentário
