Ir para o conteúdo principal
The Suzuki Swift is a subcompact automobile manufactured by Suzuki, a Japanese automaker. The second-generation Suzuki Swift was introduced in September 2010 and replaced with a new generation in February 2017.
I loose power when accelerating and sometimes when in traffic
Intermittent stalling immediately after starting or punching gas. Sometimes also in traffic. I have tried changing the CVT, testing sensors, What might be the issue?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Sounds like a fuel injector issue. Could also be a vacuum leak.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I have to check this...But how would I check a vacuum leak ?
por
That is difficult unless it is a big leak and you can hear it. Disconnecting or pinching off vacuum lines might give a clue, but that involves much understanding of what you are affecting. My bet is on the injectors.
por
Hi mate. Did you fix your problem?
What if your throttle was clogged?
Pontuação 0
2 comentários:
I've fixed a clogged catalytic converter that did something like this. I drilled a 3/8" hole in it.
por
might be fuel filter also that need to be cleaned or replaced..
por
Adicionar a sua resposta
William Afrika será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 31
Ao todo: 667
