Why is my Zealot S30 Bluetooth speaker not turning on
After charging my Zealot S30 Bluetooth speaker today for some hours, I tried turning it on but it won't come on. It charges but it just simply won't turn on.
Esta é uma boa pergunta?
Pontuação 0
6 comentários:
Abdullahi Abdulkareem how old is the speaker? Do the LED's come on at all? Do you have any sign of life on the speaker?
por
@oldturkey03 the speaker is over a year old now. 1yr and 4months old. It charges when I plug a charger to it. The red charging notification LED light comes on. But when I try to turn it on it doesn't respond. The blue LED notification light indicating it's turned on doesn't come up.
por
The same situation with "Zealot S51"! Reset button is not in aux jack nor in blue led or in microphone hole :( None of possible simultaneously pressed button combination doesnt work. Any solution? :(
por
I completely drained the battery. And now it works fine. But I hope this is not the only solution for the future.
por
@pavel How do you drain the battery when it doesn’t turn on?
por
Exibir mais 1 comentário
Adicionar um comentário
