Ir para o conteúdo principal
Why isn’t my iPod turning on?
I have an iPod touch 4th generation that does not turn on, and the screen will will turn white for as long as I hold down the power button, then go dark again, wondering if there is any easy way to fix it, or if it requires board repair.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Check that you have firm cable connections. Remove any debris from all ports. Try a different charging cable, power adapter, and power source. Don't use an adapter or cable that shows any sign of damage.
Regards,
Will
Esta resposta foi útil?
Pontuação 3
It's old now, try turning it on with the charger connected. If not, try a new battery.
Pontuação 1
Adicionar a sua resposta
someguyidk será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 168
