Trying to set up my recently factory reset phone
I can't get the drop down menu to show up and when I try to connect to wifi I get disabled or authentication problem or saved how can I get my phone to connect to my wifi
Esta é uma boa pergunta?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 48
Your WiFi password is on a sticker on the router if you forgot it.
por [deleted]
@simone_i There's no settings menu if the phone has been restored. WiFi connect screen shows up as you go through the set up process.
por [deleted]
Let's start by ruling out the obvious: the wi-fi password you typed in might not be correct, touch the Home Key > Menu Key > System settings > Wi-Fi, touch the Wi-Fi network name and then touch "Forget". Restart the phone and try to connect again; for the sake of convenience, in case of a really long and complex password you could also use WPS, altough it's not recommended to keep this feature enabled (read https://www.tomsguide.com/us/home-router... for further details): Touch WPS symbol in Wi-Fi menu and press the WPS button on the access point, it will recognize your phone and automatically add it to the network
por Simone
@strongbow you're right OP is definitely going through setup process, I assumed the psw had been typed in alredy, that explains the drop down menu not being displayed
por Simone
