locked out of iBook
I was locked out of my iBook it will not let me to enter with my psasswork or change it?
Esta é uma boa pergunta?
What OS are you running?
Is this a Firmware lockout or a munged login?
What do you see at startup?
N.
Esta resposta foi útil?
every time i enter the password it tell me that you are unable to log in to the user account " user name" at this time
Ron, Is there and Apple Store near you? They can enable another master user account and you can migrate your information to it. That seems to be a good solution.
N
You should call Apple or go to an Apple Store to get the answer to your question.
thank you +
You could try using a mac os install disk, and use the reset password utility. If you are locked out of the firmware, then you can reset the PRAM by holding command+option+p+r simutaniously during the chime until it chimes 3 times.
I do not the install disk
You might try and enter "root" as your user name and then the password you think it is. Give it a try
and if it works go to Accounts in the " system preferences" and verify your user names.
good luck
+ vote, I did not know that
I thought you had to manually enable the root user?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,855
