Ir para o conteúdo principal
Repair guides and disassembly information for tablet computers manufactured by HP.
20 Perguntas Visualizar todos
I cant play hulu on hp slate pro 21
i cant play hulu on hp slate pro 21
Update (10/08/2022)
its android 4.4 says incompatible. Disney says the same
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
So I know you can download the app (also called an APK) from 3rd party sites. I have an APK download you can try for Hulu that works with android 4.0. Just as an FYI, getting older apps to work can be a hit or miss because companies may not support the older app. You are more then welcome to try, and out of caution, I did check the APK here and it's safe to download.
Worst case, you'll have to use a browser to watch hulu on your android device.
Hulu APK
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sandra Maldonado será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 72
