Ir para o conteúdo principal
The Xiaomi Redmi 9C is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a 5000 mAh battery, and runs on a Helio G35.
Why a compass app.is not workin properly
I bought a compass app. and installed but after many tris is not working properly .Thxs
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Almost all smartphone compass apps are notoriously inaccurate.
Take a look at "http://www.tru-path.org" to see research results regarding fixing residual (after calibration) compass errors; and watch for the TruPath Compass app to be released soon.
por
Adicionar um comentário
1 resposta
Solução escolhida
Many compass apps work by using data from the magnetometer sensor, first you should check if your phone has this feature.
If it does and you have a magnetic case it could be interfering with the compass, try taking the phone out of it, recalibrate and reboot.
Alternatively, you could search the playstore for compass apps relying solely on GPS, such as 'gps compass navigator'.
Hope this helps
Esta resposta foi útil?
Pontuação 2
1 comentário:
Yes, the redmi 9c do not have a magnetometer sensor (because this is a budget phone and they want to cut cost)
Hope this help too
por
Adicionar a sua resposta
tony será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 1,951
