Won't turn on
I tried plugging it into the charger but it won't even charge or power on.
Esta é uma boa pergunta?
Hi
If it’s showing no signs of life it could be caused by many different things such as
A bad/dusty charging port,what I would do is make sure the charging port is free from dust debris and corrosion,if any is found I would use some fine tipped tweezers to remove the dust and debris then clean away everything else with some isopropyl alcohol and a toothbrush or a Qtip/cotton bud
If that doesn’t work I would start looking towards the main board and battery, here’s a disassembly guide
Substituição da placa-mãe do JBL Pulse 3
I would check the board for anything off like corrosion or any form of damage,if anything is corrosion is found I would clean it away with some isopropyl alcohol and if anything damage is found let me know about it in the comments and il tell you how to fix it accordingly:-)
After that it’s most likely a bad battery that will need replacing
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 38
Ao todo: 684
