Ir para o conteúdo principal
Informações de reparo para o cartucho de jogo usado em jogos de Game Boy Advance, também conhecido como AGB-002.
Pokémon Emerald Game Problem
So I bought the Pokemon Emerald cartridge(The previous owner glued a new battery with tape...). When I started the game I've noticed that the start screen logo was messed up also some other graphics were missing from the game. For instance I couldn't see the three pokeballs in the beginning when it was the time to choose my first Pokemon. As soon as I saw that I've opened the cartridge and found some corroded pins and traces(Some of them missing). The RTC IC had a missing and corroded trace.
Imagem
Imagem
Imagem
Imagem
Imagem
I've cleaned them and re soldered the Rom and Flash Ic's, but nothing changed. Could it be that the ROM is faulty or something else?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi
I would do over all the pins and make sure there aren’t any loose pins at all
Also keep a eye on the vias as they can have corrosion inside of them and check for any broken traces or anything that looks off
If the board has no more issues it could be a corrupted data on it
As a guide I suggest you watch this video as it shows a lot of the faults that it could be
https://m.youtube.com/watch?v=xYUW0uVBp0...
If you still can’t find anything feel free to add some more photos of the whole board using this amazing guide
Adicionar imagens a uma pergunta já existente
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Kostas Goldenmouth será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 31
Ao todo: 1,407
