Ir para o conteúdo principal
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
Fixing Micro USB-Port without replacing/soldering
Hi there! I have an Xbox Controller with a not reliably working Micro USB Port. If I push the inserted connector of the cable up, the controller loses connection. If The cable is inserted normally without touching, the controller works 100% fine.
This is an common issue on the xbox controllers and I know how to replace the port. The thing is, I am getting to tired of completely desoldering the port, getting angry if I accidentally strip traces, repairing the traces and soldering on a new one port. It is a minor issue and the port works , if connected "properly. The issue is somewhere in the connection between the port and the plug. Do you know a way to fix it without replacing the whole port? Disassembling the controller is not a problem at all.
Thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Port will either need replaced or re soldered. If you keep charging it the way it is you’ll end up ripping pads off the board.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mister T será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 31
Ao todo: 1,538
