Ir para o conteúdo principal
Zigbee 3.0 protocol compatible with all major smart brands like Philips Hue, Samsung SmartThings, or Amazon Echo Devices with in-built smart hub. 60 watt. Color bulb, E26 Base. Model: ‎AE 280C-2
How do you remove the plastic top for repair?
I would like to attempt repair of a bulb that died after one year, and another that just flickers - but can't figure out how to remove the top plastic part to get to the mainboard without damaging it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I was finally able to get through by slicing a utility knife around the seam with multiple passes, could probably be done more safely with a rotary tool. Careful not to go too deep there are a few things on the board that stick up past the seam.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ReticentRobot será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 297
