Ir para o conteúdo principal
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
20 Perguntas Visualizar todos
Digital Crown replacement procedure
How to replace Digital Crown?
My digital crown watch is all time crazy, so Watch is generally few usable.
I have to disassembly until housing completely, and then, get out digital crown, right?
Could be get out the crown before back glass?
thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sadly you do need to remove both the the SIP and sensor array assemblies to gain access to the crown mount to remove it. But you could see if using some 90% reagent isopropyl alcohol to flush the sensors and crown pin.
If you've never worked on watches you might want to just let Apple do it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Antonio será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 18
Duração total: 882
