Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
constant restore loop after logic board replace
after replacing the logic board the iPod boots to a white screen asking you to connect to iTunes and Restore. iTunes fails during the restore due to error 1416/1415. This happens in both Windows and Mac OS X (tried tiger, leopard and snow).
When I look at the partition via pdisk, it says that there is no valid block 1 on the device.
Do I have a bad hard disk or is there another fix I'm missing.
Richard
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Try unplugging all USB devices other than the iPod cable, keyboard and mouse. Sometimes when trying to do a restore other USB devices can interfere in the process. I that doesn't work then you should try to take it apart and replug all of the cables to make sure they all have a good connection. If that still doesn't work then it probably has a hardware problem. That would mean either the logic board, hard drive or possibly even the hard drive cable.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Richard será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 1,777
