Ir para o conteúdo principal
The fourth-generation Surface Pro tablet, released October 26th, 2015.
Screen flicker/shaking after changing display
I replaced the display on an SP4 I have, and everything seemed fine. However, after now replacing the SSD drive I a running into an issue where after using the device for about an hour or so the screen starts "flickering", and shaking around.
I have read all about "flickergate" and the many suggestions on potential fixes with no change. (When the issue starts if I shut down and go into UEFI mode the issue remains).
Is it possible the fan is not starting up? Is there an easy way to tell without opening things up again?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Well, I dont know if there is anything wrong with the fan - but def. confirmed its a heat issue. While watching a movie yesterday the screen started doing that thing - I used an upside down can of compressed air on the back of the device and the picture returned to noral. For a little while
I guess I will take it apart and check the fan - just dont want to go through all of that again
por
Adicionar um comentário
1 resposta
HI.
I had the problem of screen flicker when I replaced the screen on my tablet pro 4 with the spare part sold by ifixit. I finally had to opt for the Surface Pro 5 screen, which is compatible. You'll find my commentary on this subject here, which you might find useful:
https://fr.ifixit.com/R%C3%A9ponses/Affi...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Justin Greywolf será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Ao todo: 301
