Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Jammed Power/Lock button
Top/power button jammed. What happens if I don’t fix it all and just use the accessibility button?  Are there situations where having the top button working will be absolutely required? I tried cleaning but it didn’t work. Maybe the inside radio/push button is faulty. How to fix it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi
I would take the phone apart using this video guide to remove the buttons assembly
https://m.youtube.com/watch?v=pOSmov-zYF...
Here’s a iFixit guide too
iPhone SE Volume Controls Replacement
Once removed try and remove any corrosion or any dirt and debris by cleaning it with some isopropyl alcohol to help free it up
If that doesn’t work you may have to replace the buttons assembly
Here’s a link to the part
https://eustore.ifixit.com/products/ipho...
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Kunal Jain será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 90
